Time for a Rebuild?
carter
I have an HM100 with a TC on it.
It's been a long time since I've posted here since I haven't been able to ride for quite some times, last week I went out for a ride and when I came back I noticed alot of smoke coming out of the breather. When I went back I noticed a trail of oil leading into my shed, then a puddle in the shed, when i checked the dip stick the level was low. I did alot of top speed runs that day and have no clue as to how much oil was in it while I did them. I know at least I'm going to have to investigate this oil leak, which as far as I can tell looks to be around the output shaft or somewhere around there (it's hard to see with all of the plastic shrouding this thing has). My question is, should I just assume a rebuild will be necessary now and start pricing parts or try to play it by ear?
Russ2251
AZUSA:Powered by LAWN-BOY
Never assume anything.
Find the source of the leak before proceeding.
I'd hate to find out I did a complete rebuild just to discover the breather was faulty, or worse yet...a cracked block.
solomon
ca
First thing id do before i bought a replacement seal would be to go through it. If you ran it hard on low oil it could have scored the cylinder walls or scored up the connecting rod. Pull the head and the side cover first.
carter
Where might the side cover be on an HM100? I finally got to starting, and got the engine where I can see it, but then I ran out of daylight.
Also does this side cover have a gasket or anything?
