It feels like my old bike (diamondback sorrento) is getting worn beyond the point of repair... here's the short version of why I think so. I'll usually go for a fast 5-10 mile ride 2 or more times a week.
-Wheels are coming untrue faster and faster, they start being noticably untrue after about 2 weeks after being trued by a shop (tried 2 different shops). Spokes are all tensioned. V-brakes make this a really bad problem.
-The freewheel's smaller sprockets are pretty worn down.
-Rear derailleur is wonky... won't adjust easily anymore, everything is clean and either lubed or loctited and still loses its settings pretty quick. Doesn't shift, double shifts, or delay shifts a lot. Does this on the larger barely worn sprockets in the rear and the smaller more worn ones.
-Front wheel has cage bearings. Binds up with loose bearings for some reason. Rim is rough and braking is wonky.
I wasn't looking to spend much... I was thinking about one of these:
http://www.walmart.com/ip/Huffy-26-Black-Widow-Bicycle-Black/14122727
And I'm probably going to get new pedals and a good chain right off the bat. Possibly a rear derailleur. I have a pair of kenda 838s and some thick tubes I'd throw on it too. Any thoughts?
The disc brakes would be a major plus for me since I'm cheap and don't want to need to get my wheels trued very often. Shocks are a must, I go up and down curbs a lot. This would be road/sidewalk ridden... almost all concrete and asphalt, no jumping more than a foot or so.
That Huffy would be $300+ here! But still, unless you want dual suspension (assuming yours isn't dual suspension) or the convenience of having a spare bike then I'd stick with the one you've got.
