Tierods bending
trpltongue
Ok, here is the part I mean. If I tighten this all the way until it's snug, the wheel has no downward movement possible because the heim joint locks it in place. But if I leave it loose like it is, it slaps around. Not sure how it's supposed to be?
I mentioned in post #13
- a small spacer (around 1/4") can be used to increase the amount of travel between the heim & the steering arm; this can be as simple as 2 or 3 small washers...
The same applies to the kingpin; if you don't allow enough travel, they simple won't travel... at the moment, the heim joint doesn't have enough room to travel before hitting the spindle tube
You have enough length on the bolt to add a 1/4" spacer to the top & bottom of the spindle, between the heim joint & the spindle tube; do so & that should illeviate the problem
trpltongue
Fabroman, thanks for the explanation. We were trying to think of what we could use as spacers but didn't really come up with much. That kingpin bolt is 5/8" I believe. I guess we could look for some 5/8" washers but most of them are fender washers so they wouldn't do much to alleviate the travel issue :). I'll tell my brother to keep a lookout for normal 5/8" washers.
