It really is quite simple; get yourself a pair of female heim joints, screw them onto the ends of the tierods & bolt them down to the steering arm on the spindles; for best results:
- right hand threads should be used on the right side of the tierods, left hand threads should be used on the left side of the tierods (for ease of adjustment); this depends on your current setup, please check the tierods to see if you have right & left hand threads or only right hand threads
- a small spacer (around 1/4") can be used to increase the amount of travel between the heim & the steering arm; this can be as simple as 2 or 3 small washers
- if necessary, twist the steering arm on the spindles so that they line up with the tierods angle with the wheels straight, sitting on the ground; this will allow for even more travel without damaging anything...
