Anyone know the correct name for this type of tie rod and where I might find one?
qtband Well-known member Messages 1,766 Reaction score 60 Location St. Louis, MO Jun 2, 2012 #1 Anyone know the correct name for this type of tie rod and where I might find one? Attachments tre.jpg 97.1 KB · Views: 23
M mckutzy Well-known member Messages 8,353 Reaction score 107 Location bc, canada Jun 2, 2012 #2 They are called heim joints or Rod end bearings.
Doc Sprocket ********* Messages 15,677 Reaction score 142 Location Ontario, Canada Jun 2, 2012 #3 No. That is NOT a heim joint, rose joint, or spherical rod end bearing. That is just a standard industrial/agricultural rod end. The attached image depicts a Heim joint, aka rose joint, aka spherical rod end. Attachments 19296_03PRH.jpg 27.3 KB · Views: 2
qtband Well-known member Messages 1,766 Reaction score 60 Location St. Louis, MO Jun 2, 2012 #4 Thanks guys. I found them at Quickie Parts. $6
M mckutzy Well-known member Messages 8,353 Reaction score 107 Location bc, canada Jun 3, 2012 #5 Pardon me, I guess you do learn something every day. I was not aware of a difference. ...kinda like kleenex, same $hite different pile..
oldbikerarlo Old guy Messages 449 Reaction score 2 Location Marana, Az. Jun 3, 2012 #6 qtband said: Anyone know the correct name for this type of tie rod and where I might find one? Click to expand... If you use to steer a go kart, its called death on a rod
Doc Sprocket ********* Messages 15,677 Reaction score 142 Location Ontario, Canada Jun 3, 2012 #7 Yes- not something you should trust your life to, once you start getting into higher speeds and hairier situations.
qtband Well-known member Messages 1,766 Reaction score 60 Location St. Louis, MO Jun 3, 2012 #8 It's stock on the Ken-Bar Stinger 2 seat kart.
