Re-and-re'ing a throttle shaft is dead easy. Undo any linkages, and remove the screw(s) that retain the throttle plate on the shaft. Then, draw the shaft straight off.
That said, WHY is it sloppy. If the shaft is worn, just replace it. If the shaft bore in the carb body is worn, it's a whole other ballgame. You may have to ream the holes straight, tru, and larger, and install bushings to bring the bore back to spec. Depending on your situation, you may be better off replacing the barb body.
