I would check that all linkages are attached aand working properly (test with kart off). Press pedal and have someone check if the throttle lever on the engine is being pulled. Let the pedal go, and check that the throttle lever is returning to its original position
If it isn't, then there are a few options. You can either have a throttle cable where the cable in the sleeve is sticking, not allowing the cable to return. You can oil the cable and see if this helps. You might have a bend in the cable that is too sharp for it to return properly as well.
The return springs on the pedal or on the throttle lever could be gone or worn
Check all of these
