Throttle problem
buckikartr
I have a 6 hp Subaru Robin 160cc. The throttle seems stuck and I do not get any response from the foot pedal. wth????:confused:
SCK
Custom builder
Not for you to know!
Well have you checked to see if your cable is still connect to your throttle on the engine? Take some pictures of the the throttle linkage and pictures of were it hooks up to your engine.
but before you take pictures look at it and see if your throttle
linkage is still hooked up!:D
buckikartr
everything is hooked up, it was running perfect and then it started to just open up all the way.
SCK
Custom builder
I Had that happen to a engine after I dropped it! and every time I started it it went full throttle after that! Later I found out the problem their was a small tiny chip in the throttle butterfly thing.I Guess it was enough to let air in though that tiny chip. So take your carb off and look at the throttle butterfly and if you see any thing even if it looks like a scratch it is probably a small crack letting air in if you do see that this is the problem then you are going to need to buy a new throttle butterfly for you carb or buy a new carb.:D
I would check that all linkages are attached aand working properly (test with kart off). Press pedal and have someone check if the throttle lever on the engine is being pulled. Let the pedal go, and check that the throttle lever is returning to its original position
If it isn't, then there are a few options. You can either have a throttle cable where the cable in the sleeve is sticking, not allowing the cable to return. You can oil the cable and see if this helps. You might have a bend in the cable that is too sharp for it to return properly as well.
The return springs on the pedal or on the throttle lever could be gone or worn
Check all of these
