Throttle Linkage for Briggs 130202
flexedcj5
I recently purchased a go cart for my son for xmas and the gas pedal had never been hooked up. I am trying to figure out all the correct linkage but i think that some might be missing. It is a the old Briggs 130202-1672-02. I think i fianlly have the linkage correct on the top near the caburator but the governor linkage is not functional. There is a rod coming from the governor arm to the top of the motor connecting to the throttle arm, and there is a spring connected from the governor arm to the slide that the throttle cable connects to. When I move the throttle cable the slide moves but does not move the governor arm at all.
Please help I am trying to get this functional before xmas.
Thanks
Craig
flexedcj5
I ended up bypassing the governor and was able to get it working. Thanks for the responses.
buckwheat
Lilburn, GA
Hello-I am in the same boat!! Someone removed all the linkages from the governor arm and the other linkage mounted to the gas tank's support bracket.
I found the following video helpful in re-attaching those components:
http://www.youtube.com/watch?v=hK2sZjavTaw
there was another video that shows a spring connection between the two assemblies:
http://www.youtube.com/watch?v=vGgW68BjXv8
I am using an aftermarket throttle arm so I will have to make up the linkage to suit that configuration. At least the videos show what goes where....
