throttle hookup on gx390 & Yerf
fishblock
katy, tx
I got the engine running, clutch working normaly and kart runs SLOWLY. found that my throttle setup is pulling only half way. I need a better way to secure the outer cable to the engine, how are you guys with yerfdogs doing this?
t0x1k
Vroom
South, NJ
See the spring? Mount the cable in the hole there and mount it to the prefabbed cable mounting spot, next to the spring/screw adjuster.
You'll pull full throttle easily.
Also remove the spring on the throttle rod, this limits your travel on the pedal a lot. Add a spring to the throttle arm and engine.
I'll get you pics of mine later today. I've got a 3200.
