throttle cable
mikepctvman
South Florida
while rebuilding the carb on my 5hp briggs I discovered the previous owner had zip tied the tip of the throttle cable to the idle screw spring, then attached a spring to the throttle lever to pull it back closed when you let off the throttle. any kind of way to securely attach this better? ill get a photo if needed :mad2:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
As a last resort do something similar with wire instead of zip ties. but first pictures.
