hellsgrave
I'm a bit confused with the throttle on my gokart. On the carburetter there is a cable that controls the engine speed and on the bevel gear box for the self drive system, there is a cable that controls if the engine is powering the wheels. Which is for the throttle and clutch. Should I have the two pedals side by side so when I press the accelerator the clutch is press at the same time. Should I use the bevel gearox at all? The engine is a two stroke so can be turned on its side. If I dont use the bevel gear box would it be best to use a cable or a chain? By the way i'm using an engine from a Victa two stroke lawnmower. Photos on this thread: http://www.diygokarts.com/vb/showthread.php?t=6926
