ibrahim123
- Messages
- 123
- Reaction score
- 0
Okay hey guys you are probably saying " what the hell is this title " right now. Well ill tell you what its about. First let me show you my kart up to now.
The engine will be sitting right next to the driver on the right.
The rear suspension will look something like this.
When i ride it in the fields i will probably go across many bumps which is why i have the rear suspension, to make it a smoother ride (HOORAY). Now we have 1 problem. When i go across a bump the shocks will shorten from the force and therefor that circular motion will be created and that will cause the axle to get closer to the engine which means that the chain will not be tensed. This will probably cause the chain to fall off or not function well.
Now here is where the circle comes in. We know that the distance from the center of the circle to the any point of the circumference is always the same. What if applied that to the kart. Here is a drawing of my thought.
As you can see the engine sprocket is acting like the center of the circle and the axle sprocket is acting like a point on the circumference of the circle. This way, whenever the shocks work in bumps, the distance between the 2 sprockets will still be the same and that means that the chain will remain tense all the time.
Now this is my thought and it makes a lot of sense although u can never know for sure if something works before you test it right? Anyone got any opinions related to this?
And lastly the second problem is that say i drive on a rock on one wheel (lets say the right wheel). That wheel will move up a bit and the left one will stay on the floor.
This is how it would kinda look like if you guys didn't understand.
Now that means that the chain will move more to the left or right. We dont really care about up and down but sideways. I'm guessing that it might damage the chain or again fall off. Can this problem be resolved or is this not even something that i should worry about? Any advice is respected. THANKS FOR READING ALL!!!
