wheels
- Messages
- 170
- Reaction score
- 0
Ok... so, as I mentioned in another thread, I purchased a lithium Ion 40ah battery pack for my smallest Campground cruiser. The 22ah were not giving the run time I had hoped for given the riding conditions(took it hunting in mud, through hills, etc). Anyways, a couple of the smarter guys(literally... not joking) on here warned against the battery pack bc of the max continuous amps, ratings vs actual, etc. So, a shunt was suggested for testing.
I ordered the shunt... wired it up and fried my first controller. Lol ****. Ok... late in the 7th inning, spare controller called into the game. Wired it up, correctly this time, and off I went with testing. Calibrating the dang display was another story. Hoping I am reading it right. Open to suggestions, if I am not.
By the way, this test was done with my 22ah batteries while I was standing next to the buggy... had it raised up on jackstands. Also, i had the highest speed set out of the three possible on the controller.
On to the goods. The max amps I saw were 5.1, which I am assuming is 51amps. Makes sense bc the wattage was showing around 160-170 range(assuming this is 1600-1700). Like I said... I dont think I had the display calibrated right. Anyways. I did several different variations of throttling, trying to get more than 5.1 amps to show.
3.2, 3.3 amps was the consistent reading when holding the throttle wide open.
Most of the spikes in amperage were limited to 4.7, 4.8, 4.9... and then, like mentioned above, 5.1 showed as the highest.
Next up will be testing while I am riding it.
Motor/controller combo I purchased:
https://www.amazon.com/dp/B07KF8M5W6/ref=cm_sw_r_other_apa_i_4Z.xEbZS3GM23
Shunt:
https://www.ebay.com/itm/163914796173
Battery I purchased:
https://www.ebay.com/itm/184160333228
And I am attaching some pictures I took during testing.
Thanks.
Shunt:
Thanks.
