terrible problems
kendelrk
redneck engineer
westland michigan
after all of the clone problems, finally. its not the clone this time, this has happened twice once on thursday once today, the chain is slipping and falling into the back sprocket and locking up the back tire which shouldnt be happening, so now its messed up a new masterlink and the chains messed up links are coming out and its not a pretty sight, so instead of buying just a chain and all i figured id do a bit better and deiceded to save money for a selling that has a new 3/4 max torque clutch up to 10 hp, a 41 chain, master link, 2 set screws and the keyway, i dont know if the chain is supposed to come around under the axle for the brake or over it, no idea which way to go with the new chain
redsox985
PA
Don't use 41 chain, it's much weaker than 40,420,428 chain. As for the rest of that, I didn't understand much of what your problem is...but I'm also exhausted ATM.
kendelrk
redneck engineer
westland michigan
will a number 40 chain still fit a 41 clutch and sprocket? and the chain keeps breaking and coming off into the rear wheel
