Term for this bearing?
Qmavam
I have an old Fox cart. I need a bearing for the rear axle.
The bearing fits in a couple of flanges that allow the bearing
to swivel in all directions for proper alignment. The outside is rounded to allow it to swivel.
What do you call this type of bearing and where can I get them?
Thanks, Mike
residentg
...why did I do that?
pillow bearing, you need to know the diameter of your axle to get the correct size:
http://www.bmikarts.com/shop/?shop=1&cat=260
Axle Bearing
Axle Bearing
Choice of 1", 1 1/4", 30mm or 40mm Bore
Part # 400150, 600640, 600643 or 600645
SKU Number:400150, 600640, 600643 or 600645
Price: $4.95
residentg
if those bearings need replacing on your cart - check the jackshaft and front wheel bearings as well, they are cheap at ~$2 each.
