temperature gauge
The Product
Willow Beach, Ontario
hey guys
i wanna put a temp gauge on my engine its a 6.5 clone.
now, wheres the best place to put it eg. head, block, etc.
i want to monitor my motor in case its running to hot and it needs to take a break so if you guys could tell me a location and the temp i should let it cool down at that would be awesome:)
1992suburban
I wanna go FAST!!
Sanford, NC
CHT (cylinder head temp) will fluctuate with heat range of plug as well..
EGT (exhaust gas temp) monitors lean/rich mostly..
in theory both will work for monitoring overall engine temp..
if EGT is high motor prolly LEAN, and will/could run hot..
CHT temp high it could be lean/and or to hot of a plug.
its up to ya really how about sticking a probe in the dipstick and monitor OIL TEMP???
anderkart
Surprise Arizona USA
If your going to rig up some type of automotive temp gauge to your 4-stroke kart engine, I think suburban's Idea of monitoring your oil temp would probably be the way to go. This isnt normaly done so you'd have to figure out the best location and method to instal the sending unit in your motor. You'll probably find some of these gauges brand/models are a passive type design (sending unit permanently attached by a capillary type tube) and would not require a 12-volt source to power the gauge.
I have no idea what temp readings would be considered excessive but after you rode the kart around really hard in the summer for awhile you'd probably soon discover what's normal or too high.
note: you may find your oil temp ranges are higher than automotive coolant temp. gauge/senders go up to. I believe some gauges specifically made for engine/auto-transmision oil temps are designed to monitor up to a bit higher readings.
Many engines used in kart racing range between 375 to as high a 500 degree cylinder head temp readings running on gasoline. (methonal powered engines usualy run a bit cooler) These temp readings would have been taken from a race kart type temp (CHT) gauge that uses a sensor ring that simply slips around the spark plugs base before re-installing the plug.
Here's a link to the type of gauge I'm talking about here:
http://www.google.com/search?source...ie=UTF-8&rlz=1T4DMUS_enUS221US222&q=mychron+4
These types of kart gauges also have many other funtions and are powered from an internal 9-volt battery. They can typicly be found used in the $50 to $150 range and I think would be a much better altenative than trying to rig up a car type temp gauge.
On the cheap and easy, I'd probably drill and tap a spot in the crankcase, and use an automotive-type coolant temp sensor and gauge. Then spend a lot of time driving under various conditions to determine what readings can be considered "normal", so that when it does get excessive, you know what to look for...
Cost? Maybe $20.
You might even be able to install it in the oil drain hole, making the install incredibly simple!
