hi guy's
i have this tecumsuh 2.50 horizontal shaft engine i am working on and it is not getting spark.
when i spin the fly wheel and hold on to the spark plug wire it gives me a small jolt but i guess it not enough to spark the plug.
also as weak as it is i think it is also intermitant.
i have put on a new condensor but it is half the size of the original ..it has the same numbers except it has a b at the end of the number instead of an a ..
it also produces a small jolt when i hold on the the spark plug wire.
the points looks good and the flywheel and pin look good..
i was hoping someone had suggestions on what to look at next ..
thanks
thanks
