Tecumseh VM100 running HOT.
Bluethunder3320
hack saw wont fit.. its gotta be cut from the inside and peeled in on itself...
i tried a 3/8" socket and no go...
bighead
Pacific Northwest USA
Die grinder with a nice reamer bit. Just do it like your porting the exhaust.
IDK thats all I could think of thats not already been said. Stick a small rag in the hole with a magnet in it. How far back does that pipe go?
hacksaw blade with tape on the end. One cut and you would be able to get it out? That is if you can cut the whole pipes lenth?
Bluethunder3320
wow i never thought of using just the blade!
it goes back about an inch.
well i got the bolt out today, so i can use a box muffer, still want to get this pipe out though.
sexyvicta
strip down engine(might get away without doin that)... heat alloy around the pipe with some kind of gas torch.... Screw out pipe. The alloy should expand faster than the steel pipe i reckon
i think that would work
but could lead to other problems:D
Bluethunder3320
at this point, im going to try a skill saw or hack saw first.
using a torch and heat might be risky. (above what, 250 degrees F?)
Do you own an air chisel? You could fold the pipe in on itself quite easily with that...
Here's something I successfully tried once to extract a broken pipe nipple-
First, I suggest soaking around the nipple with WD-40 or other penetrant for a day or two. Then-
1) Cut a rectangle of steel plate with a slight taper down it's length so that it will *mostly* fit all the way into the broken nipple by hand, and long enough that an inch still sticks out (enough to grab well with vise grips
2) Using a thin cutoff wheel in an angle grinder, or a hacksaw or file, cut a shallow groove down each long side of the steel plate so that when inserted into the pipe, the edges on each side of this groove will bite into the pipe.
3) Put 2" of the baddest, blackest, used engine oil you have into a metal pot or pan, and ready a fire extinguisher just in case
3) Grabbing the extractor you just formed in a pair of vise grips, put the torch to it, getting is as hot as you can- cherry red, especially the edges.
4) Immediately quench in the used motor oil. This draws carbon from the oil into the outer layer of the steel, "case hardening" it.
5) Once cool, repeat a few times. It will be left with a nice, attractive black finish, even after wiping it off.
6) After repeated hardening and cooling, insert your new extractor into the pipe, and give it a couple of whacks with a hammer. This is where the taper and grooves (or flutes) come in. It should bite into the pipe, and sit down lower than it would fit by hand. If you put one edge of the extractor beside the pipe's welded seam, that gives it an even better bite.
7) Clamp on your vise grips, and unscrew the dang thing!
redsox985
PA
Air chisels make quite a racket but surely do whatever job you throw their way. They're quite fun actually. Plus, the feeling in your arms after is crazy! :p
Bluethunder3320
yeah so yesterday i smelled gas so i went over to where ive got this thing parked and it was leaked all over the ground.
the entire gas tank drained out the muffler somehow....
float stuck?
ran it today a while and had no problems.
