Tecumseh Two Stroke Engine
Rear engine 86
london ontario canada
So I have had the itch to try one of these Tec 3hp 2 strokes out myself.
I tried bolting on my HS50 carb that is fully adjustable and the engine will not stay running without me pumping the primer bulb every 2 or 3 seconds.
It almost seems to run very lean and surges a lot with this particular carb. I need to find a dual needle original style diaphram carb as my original one has only one circuit and will not idle down.
Pics are on the way!
Rear engine 86
Here is a few pics of my Tecumseh 3hp 98cc engine.
I tried mounting a HS50 carb but no dice. Just bogs and surges and will only run with shots from the primer bulb.
I want to use this engine but dont know what carb will work best.
