tecumseh tries to die at idle like cammed car.
RealliveMD
My Tecumseh 6.5 hp engine lopes like a harley trying to die at idle. When I go WOT it just dies. Could this be the carb.. It cranks right up every time but I can't drive 40 yards. It can idle over 5 min without stalling. I'm tired of this go kart. It's never run since I bought it. It has clean fresh gas, spark plug properly gapped at 30 clean air filter. My 5 hp Tecumseh doesn't sound at all like that.
machinist@large
West Michigan, 49331
Sounds like it's not getting enough fuel; try swapping filters/ cleaning the carb.:D
RealliveMD
It doesn't have a primer bulb. It has a lever for a choke. It's ther. 0hh65 motor. I'm getting the carb cleaned tomorrow. After the carb was cleaned on my 5hp, it ran like a jewel.
RealliveMD
Also, I can see the throttle opening and shutting as it sits at idle. I didn't even know it could do that. And I know there's no clog in the line. i've drained the fuel twice. I'm in bed with my wife now smelling like straight gas.
oldbikerarlo
Old guy
Marana, Az.
Good hand cleaner and a shower.BUHAHA. I'm seeing a governor problem maybe.
RealliveMD
I'm getting the carb rebuilt over the next two days. Will let you guys know how it goes. The last tecumseh ran like a jewel after rebuilding the carb.
RealliveMD
Thanks guys, it cranks fine after the cleaning . It also runs ok. Still tries to die at WOT. i can patit and it whill stay cranked. I don't have a seal between the carb and motor. Doyou think this could cause a problem.
