J.S.@SMS
Road Hazard
I have a couple of questions about a Tecumseh OHH60 that I'm fixin' up. The first is, does anyone know when Tecumseh started making the OHH series engines? I found a Tecumseh service manual that seems to think that the governor that was used in my engine was discontinued in August of 1982. And the month and year of the decade on the engine seem to think that it was made in June of the 2nd year of the decade. So that might be correct, but I'd like to know, for sure, if these engines were built then. The second is, is it safe to use a light duty pressure washer (2400 psi) to clean the engine once it's disassembled?
I know that I'm going to get all kinds of feedback saying that I should fix up a briggs or something other than a Tecumseh, but the only experience I've had with a briggs wasn't very good. This Tecumseh moved my Ken bar Streaker one seater, with 22" tires and 6:1 gearing with a 30 series 6" driven. And yet the briggs intek I have (the one the animal is based on), which isn't that old, has no compression, a shot bore, and needs $108 of parts to run. And, believe it or not, the pressure washer pump that was bolted to it still works like new.
