Tecumseh Question
jinxyj
This might rank pretty high on the "ignorant question" meter, but I was messing with my 6hp Tecumseh today and was curious as to how the governor operates on it.
When you are sitting at the backof the Kart facing the engine....Which direction does the top of the governor go when it is engaged? I thought it was pretty obvious that it went all the way to the right towards the throttle linkage when engaged, but now I'm not quite sure. Just curious mostly.....
The intended purpose of the governor is to maintain a fixed (or governed) engine speed. With a heavy load and the engine bogging, the governor will open the throttle to attempt to increase engine speed to the predetermined RPM, generally being 3600. When the load is lightened or removed, the governor closes the throttle- again to obtained the predetermined engine speed.
In short- both directions. For clarification- the governor is always "engaged". The manual throttle control only alters spring tension, influencing the governor's ability to maintain said RPM.
jinxyj
Cool. That explains it about as well as it can be explained.
I was looking on the 6.5 that I was asking about in the other thread, and noticed that the previous owner had indeed by-passed the governor by running a wire from the carb to the throttle control. They then had the governor arm wired to the muffler guard, holding it all the way to the left. Thats the part I wasn't quite sure why they did. I guess it was to just keep it from flopping around freely.
