cplbradley
- Messages
- 5
- Reaction score
- 0
So before I explain what's going on, let me give you some context.
I'm a high school student, and for my small engines class, I took the engine off my old go kart that I've had for a few years. Model # is OHH60 71157D. In class, we stripped the entire motor down to nothing but an empty crankcase, cleaned everything up, and put it back together.
Now, what's going on. I've finished rebuilding my motor, and it looks good as new. But the issue I'm having is that it will only start when I have a friend hold the throttle all the way up, and if we release it all the way, it just shuts off. If the throttle is a little bit forward, then it works fine. But if it goes all the way down, it dies. (unrelated note: when it does start, I've never seen it run so smoothly, so I'm proud of myself for that
I don't know if this is suppose to happen? If I remember right, if I ran the go kart for a few minutes, then let off the throttle, it would start to sputter, then would die after a minute or so. It's obviously a problem with the carburetor, so I just need to figure out what's causing it.
I really need to know soon, because the semester ends on the 27th, and I'd really like to have a working motor. Any advice?
Thanks in advance!
Thanks in advance!
