Devonakaozzy
Insane Test Monkey
hello all! I got my kart going with a centrifugal clutch and in the process I noticed two wires. I did a little research and found that they are live wires. now, I want to put lights on the front of my kart to see at night while riding.
how would I go about doing this? I would like to have a toggle so they aren't on unless I want them on. also I would like to use a lawnmower battery so the lights aren't dimmer as I lay off the gas. I want to know how to wire this all up properly so I am charging the battery while riding and I can flip the lights on and off. there are two wires, a yellow an red. In the photo, the yellow is on top and the red is on bottom.
EDIT: Also, how would I go about drilling out the jet on this carb? im going to be putting a free flowing exhaust and high flow filter on and will probably have to drill out the main jet a size..
