tecumseh hm80 backfiring
Bluethunder3320
ok so i finally spent $100 on a crankshaft for my free engine.
i got it to run.
only things are:
(1) its a little hard to crank over
(2) it backfires (VERY HARD)
so heres a video of it running. maybe it just has to be tuned? i cleaned the carb.
things i did during rebuild:
  1. lapped the valves
  2. cleaned carb really good
  3. used marine clean to get the carbon off everything
  4. got all the internals pretty dang clean....
  5. cleaned plug
  6. upgraded the points & condensor to a sten's electronic module
  7. added a briggs and stratton fuel filter
  8. oh yeah also a straight pipe!
Bluethunder3320
one take off that pipe its to short. two adjust it tune it. those 2 things alone could make that ALOT better.
okay... i guess those could cause backfires.
im not sure about the hard cranking but maybe its just because its a brand new crank? has to get worn in a little?
the crank has been sitting in a box with newspaper since 1980 until i put it in this engine.
so it had light surface rust that i just tried basically wiping off....
Bluethunder3320
Electronic module is first suspect.
really? :ack2:
yeah as you can see in the video the spark seems to be quite random.
see that one time that it locked up dead
and the other time it shot gas out the intake and flew into the air
EDIT: well tomorrow i guess ill just put the points back in and see what happens.
Bluethunder3320
Ive been thinking about this a while.
It seems like the reason its hard to turn over is its firing way too early, stopping the piston dead at compression stroke.
I will see if i can fix this by Pivoting the coil forwards if it isnt already.
If thats already forward^^, i will put the points back in.
bighead
Pacific Northwest USA
Is it hard to turn over with the plug out?
Bluethunder3320
i put a h60 coil in it and went to fire it up.
the starter no longer works at all. FML.
not sure what to do at this point.
EDIT: also probably broke my toe because i kicked it really hard..
B man
Tecumseh FTW!
Oliver springs,Tn
did it run? don't kick it. it will only make it madder. lol. heres a thought. RETURN IT TO STOCK. a real muffler. put the points back in. and try it.
Bluethunder3320
its not as simple as putting the points back in.
i put the stock muffler back on.
for some reason i was able to pull start it easily before teardown but now theres so much compression it locks at compression stroke.
