Kelly Wood
The Mad Kartist
Ok, here's one.
I have this H50 I've redone and when I got everything done, I checked out the head bolts on a whim.
The thing ran well before but nevertheless, I still checked the bolts.. and found one loose.
Ok, so off with the head. I checked all inside and it's very clean and, looks great.
New gasket in place, I'm about to put the head back on... and I look down.
Hey, what about that parts one I got a while back? Are there differences in the heads?
So I got curious if the heads were different and if I could find one with less compression chamber to up the HP.
The other head is more used and has a bunch of carbon build up and it's even the same engine, but a little older.
Heads look exactly the same with two differences, the numbers stamped on the underside... and In measuring, the clearance for the valves in the older head are less, by about 1/8 of an inch. (meaning, the older one has less compression chamber space)
My question(s)
1. Does anyone know what the numbers mean? The newer head has: 4-0-86 on it, and the older one has 4-0-39. Obviously they're different and I'm guessing the last two numbers indicate a depth of some sort.
2. I'm guessing that if the depth is less, I'd want to consider whether the valves will hit it... has anyone done this?
Any thoughts are appreciated.
Thanks for looking.
My question(s)
Thanks for looking.
