Probably tinned brass. I've seen 'em too.
Russ2251 AZUSA:Powered by LAWN-BOY Messages 6,622 Reaction score 47 Location Huntington Station, Long Island, NY Jul 5, 2011 #21 Probably tinned brass. I've seen 'em too.
B man Tecumseh FTW! Messages 2,490 Reaction score 3 Location Oliver springs,Tn Jul 5, 2011 #22 that would explain it then.
Bluethunder3320 New member Messages 5,677 Reaction score 39 Jul 5, 2011 #23 some floats ive seen are brass and silver in the middle where the halfs are joined together. soldered? could kendel have soldered the hole up?
Russ2251 AZUSA:Powered by LAWN-BOY Messages 6,622 Reaction score 47 Location Huntington Station, Long Island, NY Jul 5, 2011 #24 Yes, soldered. could kendel have soldered the hole up? Click to expand... Depends on how good he is. I know I cannot.
kendelrk redneck engineer Messages 2,425 Reaction score 9 Location westland michigan Jul 5, 2011 #25 i probablly could of, i thought about it, but i already soldered one hole, and the second one was soldered by him and now then there was a third hole so i just said, new float
kendelrk redneck engineer Messages 2,425 Reaction score 9 Location westland michigan Jul 6, 2011 #26 well looks like the float isint working, the engine still wont idle
Doc Sprocket ********* Messages 15,677 Reaction score 153 Location Ontario, Canada Jul 6, 2011 #27 Has the float height been set to spec? This is a NEW float, right?
kendelrk redneck engineer Messages 2,425 Reaction score 9 Location westland michigan Jul 6, 2011 #28 brand new float
Bluethunder3320 New member Messages 5,677 Reaction score 39 Jul 6, 2011 #29 its plastic, so you cant set it, am i right?
kendelrk redneck engineer Messages 2,425 Reaction score 9 Location westland michigan Jul 6, 2011 #30 it has the metal tab
devino246 Official DIYGK Chem Nerd Messages 3,856 Reaction score 17 Location Lynchburg, VA Jul 6, 2011 #31 Bluethunder3320 said: its plastic, so you cant set it, am i right? Click to expand... Should be a metal connector, which you bend to set the height.
kendelrk redneck engineer Messages 2,425 Reaction score 9 Location westland michigan Jul 6, 2011 #32 yeah and on the mtel connector sits the needles small sideways L ish type peice of metal
