tecumseh carbon on plug
sexyvicta
seems to be idling quite low. Will it idle better if you up the idle rpm slightly?
or richen up the low screw a tad and see what happens. If it gets worse then lean it off lol
kendelrk
redneck engineer
westland michigan
the high speed is absolutley perfect. it still doing like it is, and if i rev it up kind of high it smotthens, but just turning the screw dose nothing, and the low screw is all the way in, it wont run if its not all the way in
kendelrk
redneck engineer
westland michigan
well took apart the carb and gave it another cleaning, and this time i decided to shake the float, theres gas in the float, could this be why?
