Tecumseh 6hp - no threaded hole in shaft
PHalpin
I replaced a tecumseh 5hp engine that was set up with a torque converter system. The new engine is an almost identical 6hp tecumseh, but the drive shaft is solid with no threaded hole...
I was going to try to get it drilled & tapped, unless there is another option??
Thanks for any input..
Paul
PHalpin
Thanks..
Upon further review, I have decided to try
A HF predator 212 7hp instead...
How do you figure the ctc distance between
The drive & driven? I realize belt length is a factor,
Is there a sticky that addresses this?
