tecumseh 6 hp no spark
jesse b
hi my name is jesse and i just bought a murray explorer go cart and it had spark until i put a new fuel line in. it was kind of hard sliding it in between the cylinder and behind the fly wheel. after this it would not pull. i noticed that i bent a little metal piece into the fly wheel it looked like it was holding the fuel line so i bent it back out of the way it is behind the fly wheel i also had pulled the pull start assembly off a couple times now i have now spark does any one have any ideas? thanks jesse
Bluethunder3320
im thinking, take the flywheel off, take the cover off the ignition module, and clean or replace the points.
assuming this is a points engine.
also welcome to the forums!
