tecumseh 5.0 engine problem
xvolcomloserboyx
i have a 5.0 tecumseh engine on a go kart i have had it running fine and perfect for a good while and i recently changed the oil and when i started it up and took it for a ride white smoke started coming out the muffler and oil was leaking out from the carb. ? is motor just no good no more or ?
slideways
Sounds like you overfilled it. Should only take like 12-14 ounces of oil when you drain it. Don't put a whole quart in.
