Hello forum members,
I am a 'newbie' when it comes to 2 cycle engines, specifically
ones that use a diaphragm pump type carburetor;I need to know where I should tap a hole for the vacuum pulse to power
the diaphragm fuel pump--would I get a better vacuum signal(this engine is a piston port design,but but has NO reed induction parts!!) by tapping the crankcase cover,or the intake manifold spacer/adapter???
I will have to make,or buy used the carburetor intake manifold for the newly acquired West Bend Power Bee Tillotson HL232B single stack diaphragm(my enigne was bought without the carb,intake spacer, nor muffler included!!) to use a vacuum/pulse fiiting for the diaphragm pump to work,but I am guessing that a cleaner vacuum/pulse signal might be had at the crankcase cover area of the engine??
If anyone know the best placeto tap a vacuum source for a piston port 2 cycle engine,I will appreciate a reply to this post!
btw,I have uploaded an intake manifold that includes a vacuum
fitting;I am leaning toward buying this part since it doesn't need additional machine work!!
