Tecumseh 10hp Cast Iron $40?
B.M.800
TheBeal.
Central PA
Found a guy who has a 10hp cast iron Tec for $40.
Is there anything I should be looking for when we go see it?
The guy had said it needs an air cleaner, and carb linkage hooked up. He said it was a horizontal shaft, said there was a pulley on it... Im actually a little concerned, I hope he wasnt confused.
Anyways, anything I should Keep an eye out for while looking it over? Oh, and cast iron isnt a problem?
Thanks much!
:D
I'm guessing it's a cast iron bore, aka cylinder sleeve. That's good. You should be able to tell when you see it whether it's a cast aluminum block or cast iron, which I doubt. Bring a magnet if unsure. I would think that a cast block is not desirable for a kart engine due to excessive weight.
I get a bit nervous when I see missing air cleaners, god knows what the engine has been inhaling. On the other hand, snowblowers come from the factory with no air cleaner, as the intake is pretty well protected and I guess there's a lot less particulate in the air in the winter.
When you check it out, you could bring along a compression tester, or just "feel" it. Although not a conclusive test, it should give you an idea. If it's not too much of a pain in the rearend (like a long drive) you could take pics and write down the model number, then research the heck out of it and go back for the purchase if things look good. I'm assuming it hasn't run in a while?
redsox985
PA
Definitely check for compression. Can't you just pull the plug and block the hole with your thumb and pull the rope? If it blows your finger off, it's got compression, correct?
anderkart
Surprise Arizona USA
:iagree:
Here's some info to help ID it: http://smallengines.wikia.com/wiki/Tecumseh_3_to_11_HP_4-Cycle_L-Head_General_Information
The earlier Tecumseh HH100/10hp blocks were solid cast Iron and then the newer models went to aluminum w/Iron bores. All these engines were very good and didn't have any inherent problems. They're designed very similar to a briggs 5hp but just much stronger and with a larger bore and stroke.
Lots of the aluminum/cast Iron bore H100 variants are still used in kart racing today, race parts are kinda hard to find but still available. Tecumseh sold a factory built kart racing version of the 10hp flathead from the early-80's until they closed down. This engine was called the Tecumseh Star, I own a couple of these and still race them.
B.M.800
TheBeal.
Central PA
130lbs! whoa!
:roflol:
Anyways, the guy said it ran in the fall. He got it from some other guy who put a biger one on his tractor, i though, uhoh.. lets hope he didnt get confused with vertical and stuff. Im going to look at it on thursday
Cool- you'll have to let us know what you find. I'm still trying to deal for a lawn tractor that uses an 18hp Briggs horizontal... Some did, you might be lucky. Still, though- if it's all iron I think I'd pass on it because of the weight.
redsox985
PA
The weight would be good on a tractor where you are geared for tons of torque and need traction, not so much in a kart where you usually want speed and drifting.
B.M.800
TheBeal.
Central PA
Yes, weight... well see what happens...
:cheers2:
Actually, I need to have this something(ive got a couple somethings in the "this would be cool to build process") geared pretty low around here... ofcourse who said I cant make 2 or more(lets go with more) things to ride... one for whooping my buddys kart offroad-ish and one to whoop his going fast!
hehehe...
:wai:
element10554
Glen Mills Pa
For 40$ if it has compression parts are available and especially if it runs I would go for it regardless of the weight. Its only 40$ im sure there is something you could make with that engine.
B.M.800
TheBeal.
Central PA
We might not be able to go see it today (crap) my brothers car is having issues.
If it is cast iron block, we have a rock crusher(YES we can break stuff) in need of a motor, So it might work for that.
