Themurraykart
- Messages
- 75
- Reaction score
- 0
I have a 5hp powersport I want to get running. The issue is the carburator is pouring out gas. I think the float is maybe missing a spring because the float valve is falling out every time I try to reassemble everything. Also where do you find carb rebuild kits for these engines??? And other gaskets! My recoil also broke but I can still manage to get the engine started If I wrap it arround the flywheel. I am trying to be as cheap as possible! Also how do you change the copper ring on a max-torque clutch???
