tec hm80 with straight pipe
techm80
cape cod MA
alright guys, ive got a couple questions about the threaded exhaust port on my tec... i bought a 1'' threaded pipe that a foot long and it wont wont fit.. its way to big, i measured the port and it was 1''!!!!!! what am i missing????? so i remesured the pipe and it turns out that its a little over an inch.. even tho it was in the 1'' section. so can some tune in and tell me what i should do. and also is this a good setup??? the motor is stock and un-governed
thanks in advance
However, having the pipe inside the port will be restrictive. For best results, you want a pipe that has the same or larger ID than the port
newrider3
Colorado
Actually, the exhaust ports on engines designed to accept NPT threaded mufflers are oversized and actually inefficient when there is no pipe threaded inside. A common trick among Briggs flathead racers is to thread a small aluminum pipe nipple into the port to act as a reducer when running a bolt on header.
Ha, I got schooled :roflol:
All good
