Tec Carb Question
qtband
St. Louis, MO
I cleaned the carb, but didn't replace anything. If I screw the circled screw all the way in, it doesn't idle correct. If I turn it out it idles OK. My question is...isn't that screw supposed to be all the way in? In which case I need to do a better job cleaning the carb or replace some consumable parts.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
No, that screw controls how much fuel flows through the carb during idle. Hopefully you didn't tighten that screw much. If you put too much pressure on it, you may have damaged the needle or the seat.
jamyers
Buffalo Gap, TX
What devino said. :iagree:
That's the idle mixture screw, it controls how rich or lean the fuel/air mix is at idle and low rpms.
Generally, turn it in all the way lightly (don't honk down on it), then back it out 1.5 turns as a starting point. Then, start the engine, let it warm up completely, and adjust it in/out for the fastest/smoothest idle. Might have to then adjust the idle speed screw (it's the one that limits how far closed the throttle can go) if it changes a bunch when you adjust the idle mix screw.
I'd suggest you do some reading on carburetor operation, google is your friend there. :cheers2:
qtband
St. Louis, MO
The reason I thought it should be all the way in is because it has no spring on it. It doesn't have a point either. Just a blunt tip with 2 holes on the side.
jamyers
Buffalo Gap, TX
Good catch! (non-adjustable carbs are a communist plot, imho).
Yup, sounds like you've got some trash blocking the passage / jet.
