I know I could have had the wife draw it up for me but the contest would have been long over by the time she got it done.
Just to give you an idea of what I'm going for think goped trail quad.
The rear swing arm will wrap around the seat somewhat.
It will be the same basic design but the front suspension will be different with a leading arm from the side that will (hopefully) hold the spindle at the desired position through the suspension range.It will have a strut coming from the front of the frame but thats just to keep the suspension arm located.
Instead of the common arm(single A-arm) coming from the front, middle of the frame with the problems of the camber changes as it compress's.
It will not look like a normal gokart but I hope its easy enough to make and works well enough that others here will want to make one and I can help them with it if needed.
