bindercrazy
I bought this Go Kart the other day at a garage sale and the owner said it needed a few things like old gas and a few tires in the front but still holds air. I got it home and wanted to see exactly i had to fix and what it did. It started right up but ran a little ruff so i drained the gas, blew the carb all out, checked the bowl and changed the dirty filter. New gas and ran good. Vangaurd 9 hp B/S. Took off for a test ride and the belt did a lot of smoking when sitting. The belt after 5 minutes of ride time was too thin to make the Kart go. I bought a replacement belt from NAPA and they ordered a belt and i picked it up today. Says Replaces comet 203591 3/4 x 29.28" 7-078144. My original belt said Manco 6814df. I put on the new belt had to take the Clutch off and spread the jack shaft to get the belt way deep to get the clutch back on.
When i started it it wanted to go then and didn't sit still even holding it. It acted like it was to tight and was very hard to restart because the tires where trying to turn too. I got it going, jumped on very fast, took off and was flying. It worked great but the breaks didnt stop it very well because the belt being either too tight or clutch not turning free in the middle. After 2 trips down the road full throttle and about 5 laps around the yard my belt was frayed on the edges and strings hanging from both sides. The clutch and Jack shaft pulley are both rusty from sitting. I sanded the clutch and got about 75% of the rust off but still not shinny smooth. After running it for a bit the clutch is a little better but my $52 belt from NAPA is warn on the edges and frayed. Can anybody help me out with this before this belt is toast.
Thanks
Dave
Thanks
Dave
