dreazoian
I was just riding around for anther daily spin as usual and i noticed my go kart started acting weird like the enigne was making jumpy noises and accelerating was weird and jumpy. Then at a stop sign when i tried accelerating it wouldnt go so i turned it off and went to the side and i saw my belt had been literally like shredded. All the teeth on the belt seemed as if they were "cut off". And the belt was jammed down into the Driver. it was jammed so my back wheels wouldnt turn at all. I have no clue as to how and why this happened. But every day before this i had no problem at all, and im using the belt that came with the TC so its the right side and im guessing the tension was good because it was loose enough that i can remove it without taking off the driver first. (not TOO loose.)
