TC and Jackshaft
qtband
St. Louis, MO
I got this frame for $100 and I really like the style. I flip karts for fun, but this one I want to keep for the nephews & nieces. It had no engine or TC or jackshaft. I want to put on this electric start Honda and a TC/jackshaft that I had laying around. My question is....If I use the JS pictured, I will have to get a longer shaft. From the end of the housing to where the drive sprocket will be is going to be about 6". Is that too long of a distance without any support?
If I had to, I could replace the JS tube with a longer one, I just don't know if I HAVE to.
I did find a picture of the original set-up and it shows the TC/JS going towards the front. I will be doing that.
firemanjim
Just kartin' around....
Houston Texas
I bought one like exactly like that for $150. It's called a Silver Bullet? I sold it for $400, just cleaned carb and tc...
I would add a cheap simple shaft support. One of those washers that a bearing fits into and a piece of tube to hold it up to right height... :thumbsup:
qtband
St. Louis, MO
I did this today.
Got a piece of pipe for the new JS tube. Removed the shorter tube and welded the longer one in. I also had to add to the length of the mount because the distance between my center shafts was 5 7/8". Can't get a belt that small. I think it'll work OK this way. At least I'm hoping so.
