Get the flat faces in line and make sure the top width of the belt is 3/4" and the outer circumference matches the outer circumference specified by driven unit diameter and center to center distance in the 'comet belt chart'. Also make sure the belt is asymmetric if you have the 30 series.
I'd also make sure I had everything lined up/installed properly on the drive unit.
From the few cases we have seen, the drive unit bushing disintegrating is usually because the belt is too short. I have seen very old bushings that have worn down and one that had cracked, but none personally have blown up on me yet.
