tav2 firehawk
minibiker
USA
I have a fire hawk mini bike similar to the Baja warrior that has a 18 in rear golf cart tire, a 6 hp mitusbishi with 18 lb springs, gov removed, header, intake, rejet and timing advanced and sanded down head. It was doing 44 mph before I had put the tav on ( my first one) . I swapped the rear sprocket to 50 and 10 on the tav2. I gpsed the mini bike today and it topped out at 35 mph on a flat straight away. It went 0-25 pretty fast then slowy got up to 35. I have white driver springs with 3100 engagement and a yellow driven spring. The motor can rev more than 6000 rpms what can I do to fix this or is this typical with tav2s?
KartFab
Dallas, TX
so waht are you saying? you like speed instead of torque? You are already outside the 'bounds' of where you should realistically be between torque and speed. You can have lots of torque, or lost of speed. You can't get lots of torque and lots of speed.
Torque converters are not 100% efficient at transfer of power, so you lose some torque to the wheels through the torque converter, which may explain why you slowly get to 35.
However, I have a baja heat (same as warrior) with a stock engine and it goes to 36 STOCK (yes you heard me) stock. So something is messed up.... cant tell you waht though. Maybe your just a fatty? (no offense if you are, im 230 lbs and it gets to 36 mph easy at 3600 rpm)
minibiker
USA
I weight about the same as you what motor do u have on yours? I see the guys on you tube getting 44mph ungoverned 6.5 , the bike has more torque for like a second or two with the tav and then shifts to high gear and lags it . I did reach 43 mph but it was when it was when I was going down a slight grade and it took a lot longer than my clutch to get there.
KartFab
Dallas, TX
Hmm well it's the honda gx200 clone (jf200) really old crusty engine no mods.
My suggestion to you would be to change the torque converter to stocks down see how it performs? You might want to make sure the driven unit is pre wound correctly. Also, if you want the driven to engage later, just use a different hole in the driven (1 is for speed, the middle is for all around, and the other is for torque and "shifts" later.
minibiker
USA
I switched the stock driven springs and got more torque but the top end it the same. The yellow torsion spring is in the 3rd position. Anybody find the secret to getting these things to rev?
simple.. you geared tooo high and the engine doesn't have enough torque left to rev up.
to increase speed (or in your case, not even enough to reach the former top speed)
gear lower.
minibiker
USA
So can these tavs rev out almost the same as with a clutch with the right gearing? 5.5:1 or 6.2:1?
firemanjim
Just kartin' around....
Houston Texas
Go back to a 60..... And you should be able to hit your goal....
You mentioned mods to the engine, specifically the #18 springs. Did you put a billet connecting rod too? If not, I wouldn't be revving the engine past 5400-5600rpm.... It might make its own ventilation hole if ya do.....
We have a member who has a way custom yard kart. He's running a nodded 6.5 with a tav2 and running 50-55mph..... I WANT to say they're good for up to like 8000-9000rpm, but I can't be for certain at the moment. I know you're OK at 6000....
minibiker
USA
Ok cool so I just need to regear it . I love the take off with the tav almost wants to wheelie but I think it will when I swap out the 10 t front sprocket to a 8 tooth I just wanted to make sure that the tav can revv higher so I don't loose any speed with the lower gearing
