TAV Hub Driver
mead_hall
Orlando
I broke my hub driver. Its the piece that attaches the spinning part of the clutch to the motor shaft. Now the key inside was broken off. Now, what the hell? I had it bolted down good. Why would it do that? One thing I'm thinking is that the engine shaft barely goes in the piece when its mounted. Anyone else have this problem? Also, it rained on me just before this happened. I doubt water caused this but I'm not sure.
Its part number 5 in the pic.
mike75925
thinker and tinkerer
Alto, tx
was #10 and 11 backed up as far as you could get it without grinding the plate? others have done the same with no adverse affects, yet.
mead_hall
Orlando
Yeah I mean, everything is on as far as possible. If I cut or shave #11 I'm afraid that the belt wont line up. If there is another thread on this I would love to see it. I wasnt able to find it in search.
residentg
...why did I do that?
The driven needs to be secure on the shaft. It is possible that yours got loose which would cause the hub to break. I always replace the bolt (#1) with a longer grade-8 bolt 5/16 fine thread, use anti-sieze on the threads. Washer (#3) is a special thick washer that should not be replaced with a standard washer which could "cave-in" and cause the driven pulley to loosen. Check spacer (#11) to ensure that it is true.
mead_hall
Orlando
Sweet, thats exactly the info I was looking for. I didnt receive the correct bolt/washer when I ordered the tav so I had to get some from the hardware store. The washer did bend some. I'll have the new parts in the mail today.
