TAV 2 Brass bushing
mead_hall
Orlando
Does anyone know the specs on this thing? Mine came smashed in the box from the factory.:furious2: I called for a replacement but that could take some time. Id like to beable to run to the local hardware store and pick one up but dont know the dimensions.
I have the 3/4 bore TAV2 if that helps. Thanks guys!:cheers2:
Correction: the bushing is bronze
part number 200349A, number 10 in the pic.
Kaptain Krunch
Pro Junk Collector
vermont
Measure the dia it has to fit over, then measure the dia it has to fit in, then you'll have the ID and OD of the bushing, then run to your hardware store and try to find one.
