IDK for sure, but I think that would ruin your fuel pump eventually due to gas getting where it shouldn't. But IDK.
Vertical shaft? What's the application?
Vertical shafts arent really what we use around here for gokarts... we use the typical horizontal shafts...
What is the aplication you are using it for?...
Pics??
Yes tapping the intake manifold to run a barbed fitting for a pulse pump will work. I'm guessing running just a gravity fed gas tank is not an option? It works on the horizontal shaft flathead engines.
Well happy fishing! Hope to do some channel cat fishing this year around the 4th of July. How much of a pain was it to mate the briggs to the outboard?
Overall the project has been quite enjoyable. It takes a lot of creative problem solving and really researching for the answers but the payoff is rewarding. I think I watched every home made outboard video on youtube several times haha.all of the 4 stroke industrial engines ive dealt with get the fuel pump pulse from the crank case, and not the intake. usually valve cover, or dipstick tube.
I wish I had a valve cover to tap into. It would be easier. Would you have to order a new dipstick tube for the second option?
