I have tried a couple of those little cheapy tacks off amazon that did not work well. I got an Eqqus tack which uses an inductive pickup on the plug wire. It works poorly. RPM all up and down. I think the pickup is bad, I ordered a new one. The tach comes with 2 cable options, The inductive and it has a direct cable that would hook to the negative side of a ignition coil. Just wondering if I could hook that to the kill switch wire? Probably blow up the tach! But wondering.
