Swapping servo tester modules for Hall effect throttle pedal
Bluebeagle
We have a Victor 883 speed controller that uses a PWM servo tester and potentiometer as the forward/neutral and reverse. This is impractical for our go cart so would like to replace the servo tester with a Hall effect pedal. Both have same connnection of three pins, pos./neg/ signal. but wondering if we could essentially parcel out the work of the servo tester between the pedal and a forward/neutral reverse switch between the speed controller and motor. The pedal would act as the poise +5 v input. Any thoughts appreciated
Jeff
redflash
check out "electricscooterparts.com" they are the source for electric go karts and scooters, they've got absolutely everything you could need !
Da Flash
