brandongeiger2
So i tore open the case of my lt125 engine and removed the pressure plate to check the disks well i got everything back together but the pressure plate. Basically what i need to do is compress the spring enough for the pressure plate to go in past the groove the lock ring sits in I've tried and tried but haven't made progress...Does anyone have experience with these types of clutches and if i need some special tool to compress the pressure plate? Was that clear enough? haha
haha but i tryed use your "vice" idea it worked beautifully now i just need to get a socket that fits the nut because i cant fit a wrench into the area the nut sits in anyway i got the clutch back together and ill finally get the rebuild started
