r97
Measure twice cut once
hay all
i was just wondering if you could make a super tc if you bolted 3 tc together and adjusted the spring tension on the second two. if it does work you could have a low gear of almost 20 to 1 then if you used a 30 series a highe gear of .729 to 1, wich on anaverage kart would burn the tires and then launch you up to an insane 94mph
. any way i dont have enough $$ to make this if its possible but if any one has or will make it id love to see it!
